coil pics
coil pics
http://i774.photobucket.com/albums/y...g;C:\Documents and SettinC:\Documents and Settings\Larry\My Documentsgs\Larry\My Documents;
Assuming the red wire is "hot", coming from the ignition switch, it should go to one terminal on the ballast, the other ballast terminal should go to the (+) on the coil. The white wire should go from the (-) terminal on the coil to the distributor.
Check the voltage at the (+) terminal on the coil with the engine idling. It should be around 7 volts.
lshort
13
Dec 7, 2010 05:55 AM
homade
22
Dec 21, 2009 06:21 PM
deemac
Feb 6, 2008 07:16 AM
