Brake Lights
Old Jun 16, 2010 | 03:24 AM
generaltso64's Avatar
generaltso64
Brake Lights
I have a 89 f250 7.3 IDI, the brake lights arent working and im getting no power to the hazard/turn signals on the RH (passenger) side. all marker/parking lights are still working. Is there anything diesel specific to the light wiring on these trucks? I have a schematic of the wiring and am planning to go through all of it, was just wondering if anyone else has had this problem and could tell me where to start. Any help would be great, Thank you.
Old Jun 16, 2010 | 09:53 AM
farmert's Avatar
farmert
Are your fuses good? I would start there.
Old Jun 16, 2010 | 03:21 PM
LCAM-01XA's Avatar
LCAM-01XA
Nothing diesel-specific to the lights wiring AFAIK. Check voltage at your BOO switch, it lives on the brake pedal and moves with it - one of the wires should be 12V constant, and the other should get 12V when you push down on the pedal, you will also likely hear the switch "click" when it engages and disengages.
Old Jun 16, 2010 | 06:16 PM
generaltso64
it doesnt have the original steering column i found out, somebody had replaced it and didnt connect the harness all the way....everything works AND my cruise control started working!!
REALTREE-F150
May 18, 2014 09:44 AM
whereeaglesdare83
Sep 27, 2010 09:23 PM
CoalMiner82
May 7, 2007 07:01 PM
55ford239
May 5, 2005 02:58 PM
sdh94ranger
1983 - 2012 Ranger & B-Series
Jul 30, 2004 06:03 PM
