So I have two different problems, numero uno happens to be front door always reads it to be open already blasted with WD-40 and nothing has happened... GRRR
Second Problem is The trunk you can unlock it but when you turn the handle witch every way neither the trunk nor the glass opens up...
hi im sorry but i can only help you on the second problem,
you have to go in the trunk and pull off the trunk molding, you have to look hard there are white plastic clips on the cable that break off. the fix is to unhook the cable and put some washers on it and hook it back on.
