Brake rotor specs
Old Jun 15, 2010 | 05:57 PM
CharlieLed's Avatar
CharlieLed
Brake rotor specs
I have a 96 Explorer rear disc brake kit on a 9 inch rearend that has small bearings. The significance of this is that the axle hub diameter is 2.43 inches but the center hole in the rotor is 2.79 inches. At first I was going to machine a spacer to correct the oversized hole, but now I am thinking that there may be a rotor available that would fit without the spacer. Has anyone found a source for brake rotor specs (dimensions) whereby I could select a rotor based on size instead of year/make/model of vehicle?
Pheadrus
Aug 15, 2014 04:52 PM
VROD
General Diesel Discussion
Mar 10, 2013 07:11 PM
bri687
Jul 3, 2011 12:53 PM
bbussman40
Jan 13, 2010 02:51 PM
rvpuller
Modular V10 (6.8l)
Aug 19, 2009 07:55 AM
