binding up in reverse
Old Jun 15, 2010 | 05:55 PM
wildbill73's Avatar
wildbill73
does anyone who doesn't have a solid axle have problems with the tires toeing in and feel like the steering is bound while backing. i need new tie rod ends but i dont think that should affect it this severly.
Old Jun 15, 2010 | 06:06 PM
wildbill73's Avatar
wildbill73
also where is a good place to get a dana 60 cheap.
Old Jun 15, 2010 | 06:45 PM
LCAM-01XA's Avatar
LCAM-01XA
Yes this is normal for the TTB and TIB front suspension, especially when the tie-rods are worn. Mine sinks down about an inch when I back up, and all my steering parts are fairly new with no slop anywhere...
Old Jun 15, 2010 | 11:24 PM
greywynd's Avatar
greywynd
Good luck on that one!! Anyone that has any knowledge about trucks, knows these axles are in demand, and fetch a decent price. Around here generally I can find a complete truck for not much more than the axle by itself.
Old Jun 15, 2010 | 11:37 PM
rupejosh's Avatar
rupejosh
if my tires are low it does this at times.have you greased your tie rod ends and balljoints lately?
Old Jun 15, 2010 | 11:48 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Like stated, it's normal, it's because of the toe and caster, just pull forward a few feet and they should be vertical again.
-Enjoy
fh : )_~
Old Jun 16, 2010 | 12:10 AM
LCAM-01XA's Avatar
LCAM-01XA
Greasing worn out parts is actually is not a good thing as it creates a false sense of safety - before the grease everything is loose, after you pump 'em up full things tend to tighten up (at least by feel of hand) so folks often think the issue is fixed. If any play is felt in the steering linkage I'd recommend replacing the offending parts ASAP, better safe than sorry.
trepid94
Sep 18, 2016 11:48 AM
53 fatty
Florida Chapter
Mar 19, 2014 08:48 PM
kuch73
Nov 1, 2013 01:21 PM
kevin316
May 27, 2013 11:18 AM
