Bronco II Ford Bronco II
Themostat question
Old Jun 14, 2010 | 10:50 PM
db1068's Avatar
db1068
Themostat question
So, is it common for the thermostat to be located on the intake side of the water pump of an "85" B2? This seems to fly in the face of common sense to me. Has anyone experienced over heating problems with this set up?
Old Jun 14, 2010 | 11:38 PM
Old93junk's Avatar
Old93junk
The T-stat is normally located on the lower hose on 2.8 V-6s...........never a problem here.
Old Jun 15, 2010 | 11:11 PM
db1068's Avatar
db1068
I got it all apart. Man, what a cluster *&%! of a cooling system. The engineers at Ford must have been heavily into rubber hose futures when they designed this engine.
Thanks for the info Old93junk.
