!956 F100 Chassis Number
Hi Heven!
Welcome to FTE.
The number you are pointing to in your pics is the part number for that piece - it is stamped in.
Your serial number will also be stamped on the upper right frame rail and should read something akin to F10D6R-12345.
Here's a link with pictures:
https://www.ford-trucks.com/forums/8...n-53-56-a.html
Post it when you find it and we will decode it.
Welcome to FTE.
Which would make sense if the frame rails were made from cast iron. But since they are actually stamped steel, the numbers are also stamped, not cast.
Just trying to eliminate confusion and maintain clarity, accuracy and integrity of the forum. ;-)
Nobody cares about that kind of nit picky semantics BS despite your rationalization about accuracy? You seem to be repetative at rationalizing non constructive, sniping inputs - been mentioned before. Fixed it just for you.
The guy wants to find his serial number.
Try and focus - I know it's hard.
