Anyone know if you can buy just the connectors for the AC Compressor? Not needing the one on the compressor, but the one that is connected to the piping. Or will i have to buy the harness?
Cool, thanks guys. RIght now its rigged to run, but have an exposed wire right at the pigtail and cant repair. Before i couldnt get it to stay engaged, it would kick in and out every second.
Right now I have a jumper wire on the high side pressure switch...
The part is down at Ford, but I just had to order a new air filter from Clay so...
I would replace the whole harness if I had it to do again... $12 bucks for the compressor switch, $15 for the low side and now the high side...
