Super Duty Engines??
The 535 has a whopping 4.5" bore.
Obviously a truck engine, but has anybody heard what kind of HP one could get?
I've been around Ford for 30 years and just learned something new.
Anybody have one?
are they any good?
Read all about it:
401, 477, & 534 SD Engines - Ford Truck Enthusiasts Forums
277 hp/ 490 lb/ft, according to this:
https://www.ford-trucks.com/forums/4...yone-else.html
There are other threads there with specs as well.
What kind of HP could you get? I'd guess if you put a couple of turbos on one, you could see 350 or better, with a lot more low end torque.
Several people have them on that forum and on the large truck forum up top--mostly retired fire trucks of late.
Any good? They are obsolete. Designed when gas was 20 CENTS per gallon, they represent a bygone era. They make no sense economically or power wise for commercial use, and they have almost no performance potential for hobby or hot rod use. The weigh something like 1100 lbs as well.
You want power? Build a 460 or an FE.
FWIW, a recent thread on the large truck thread:
https://www.ford-trucks.com/forums/9...need-this.html
Not much on the 534 yet, but his runs well and is probably one of the best examples of how these work and perform in OEM condition, so stay tuned for a report from that fellow if you have a hankerin' for more 534...
Be advised if you are trying to do the "Mine's bigger" thing, you are only half way there with the 534:
http://www.youtube.com/watch?v=ilyGlrM1Q6A
http://www.fordgaaengine.com/
Here on page 3, past the insults and pedantic ravings and other posts:
https://www.ford-trucks.com/forums/9...ord-gas-3.html
