1978 A/C Mount HELP NEEDED FAST!
Old Jun 13, 2010 | 12:04 PM
Aaron-71's Avatar
Aaron-71
Is this the correct A/C mount for a 1978 F150 Custom 351 Windsor engine?
If I don't actually have A/C on the truck, I should still have the A/C mount for the power steering pump to be mounted correctly, right?
Let me know back ASAP! THANKS!
Pictures of the A/C mount, as well as one of the power steering pump are attached.
Power Steering Pump:
http://img810.imageshack.us/img810/2391/1000677.jpg
A/C Mount:
http://img811.imageshack.us/img811/7764/1000676p.jpg
Remember, these are supposed to be for a 1978 F150 Custom 351 Windsor engine. My truck doesn't have the A/C mount at the moment, so I can't see how it would help my power steering pump (as i've been told since it's missing it).
Old Jun 13, 2010 | 11:16 PM
first today's Avatar
first today
You should be able to bolt that power steering right in to the head on your motor. Look to see that the power steering pulley is in line with the waterpump and crank pulley. If not you may need to shim the bracket between the head and p/s bracket or shim it between the bolt head and P/S bracket.
Once in place and lined up, take a string around the pulleys that line up, tie it together like a belt,then go to the parts store to buy a belt the length of your string belt.
Old Jun 13, 2010 | 11:23 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
A/C Mount:
No 1973/79 F100/350 came with a 351W.
The first year the 351W was factory installed in F Series trucks was 1981.
1977/79 F100/350's were available with the 351M which has 8 valve cover bolt holes per side. The 351W has 6.
Old Jun 13, 2010 | 11:25 PM
Aaron-71's Avatar
Aaron-71
Thanks for your enormous amount of help... really...
Old Jun 14, 2010 | 12:02 AM
Aaron-71's Avatar
Aaron-71
Alright. It sounds easy enough, but I'm not sure how I can shim the power steering pump that easily. If you take a look at the pictures I've got, the first one is of the current pump and brackets I'm working with. You can see holes on the front of the head and there is a hidden hole in the pumps pulley mount.
The second picture is the pump I'm going to be buying because my current pumps seal and reservoir are destroyed. Looking at the second picture, it doesn't seem to have the same mounting style as the first picture does when talking about the bracket and head bolt holes.
Basically my question is, any idea on how to make a decent shim for the bracket and mount? Or what materials to use?
Old Power Steering Pump:
http://img192.imageshack.us/img192/8238/dscn3916h.jpg
New Power Steering Pump:
http://img694.imageshack.us/img694/6922/1000677i.jpg
Any other suggestions for how to make this pump work?
Old Jun 14, 2010 | 12:13 AM
NumberDummy
Ford changed the P/S pump on everything in 1978 except Econolines, it has a plastic reservoir. The same pump was used well into the 1990's.
1965/77 P/S pumps (except 1975 and later Econolines) have a steel reservoir.
With a steel reservoir and plastic dipstick (as pictured): 1975/77 Granada/Monarch.
If the engine is a 351W, and this pump is original to the engine, the engine prolly came from one of these cars.
Old Jun 14, 2010 | 12:54 AM
first today
You can use the original bracket that goes from the waterpump on your motor to the front of the new power steering pump. If you can not get the long bolt that goes through the bracket into the head you may need this bracket. 1970 1971 Ford Mustang Cougar 351 A/C Mounting Bracket: eBay Motors (item 220611521830 end time Jun-24-10 08:57:15 PDT) It will have a lower mount hole for the pump from the head. My motor uses the same front bracket as you have originaly. You do not need the big a/c plate bracket to mount the pump.
If you click on the picture, you can magnify the photo and see the bracket on the front of the pump is behind that big plate.
<a href="http://www.flickr.com/photos/love_ford_trucks/4664902106/" title="junkyard 143 by ford collection, on Flickr"><img src="http://farm5.static.flickr.com/4053/4664902106_5d57049021.jpg" width="375" height="500" alt="junkyard 143" /></a>
rolsen333
May 19, 2015 10:14 AM
FordManiac88
22
May 21, 2011 08:27 AM
Duct Tape Racing
Offroad & 4x4
Apr 20, 2011 02:07 PM
TheBigBee
Feb 8, 2010 10:09 PM
cooltc2004
New Member Introductions
Feb 10, 2007 07:25 PM
