Help with noise from engine area
Old Jun 12, 2010 | 11:43 PM
loopsy's Avatar
loopsy
I have this squileak, squileak, squileak noise coming from the engine. The noise is noticeable at idle when I start the truck or when going down a long hill and the engine into sleep mode and when I use the tow-haul and the engine downshifts. The squileak is not timed with RPM’s or transmission. Its been doing it for a while but getting louder and more frequent now. It’s not the alternator because I just replaced it. Could it be the belt or the water pump? Any ideas?
Thanks
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
2004, F-350, Auto, CC, 4x4, LB, srw, Fumoto, zoodad, MBRP 4” Turbo Back, EGR delete, Edge Insight with RGT probe, 89k miles, stock
Old Jun 13, 2010 | 12:37 AM
adamtheman16's Avatar
adamtheman16
While the engine is running and squeaking, spray some saopy water on the belt on both sides, one side at a time. If its the belt squeaking, you can tell which side of the belt is squeaking (most likely the ribbed side). Then you probably have a belt problem. I have fixed it before using some dielectric grease on it. Just a little dab on the finger wiped across the width of the belt is all it takes. Or replace the belt (most recommended)
Old Jun 13, 2010 | 10:51 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
I know it seems silly to mention this, but be sure you turn the motor off before you do that
Old Jun 13, 2010 | 11:11 AM
npccpartsman's Avatar
npccpartsman
It's not silly. You might be surprised how many might try it running.
Old Jun 13, 2010 | 11:23 AM
loopsy's Avatar
loopsy
Thanks for the ideas and advice. Will try and let you know.
Old Jun 13, 2010 | 12:38 PM
adamtheman16
HAHA!...Yes...I can see people trying that! I'd hate for someone to get hurt because I didn't clarify the obvious and the common sense!
