My 50cent mod
Old Jun 12, 2010 | 06:21 PM
jwhitetail's Avatar
jwhitetail
Talking My 50cent mod
Just to a heads up on my mod the other day, on my 03 i had to cut all the way down to the bottom of Washington's nose to clear the valve cover, if not it was pushing the connection back when the valve cover was put back on. I also torqued everything down, nothing was loose, all went well and it run's great.
Old Jun 12, 2010 | 06:47 PM
ChunderDownUnder's Avatar
ChunderDownUnder
Well done m8. A simple fix to a annoying problem. Whats next ????
Old Jun 12, 2010 | 07:00 PM
clintbonnie's Avatar
clintbonnie
I heard on the 03's, the loose connector problem was fixed by Ford and you didn't need the 50 cent fix..
Old Jun 12, 2010 | 08:11 PM
F350-6's Avatar
F350-6
The harness was updated at some point. Kwik has the new harness with his new engine. He cut the quarter down the same way as described above. Don't know if he did that just for good measure, or if he saw something that left him less than confident in the updated harness design.
Old Jun 12, 2010 | 09:48 PM
tdpower's Avatar
tdpower
re
Good question the newer ones had a better design and were not prone to coming loose.
Old Jun 13, 2010 | 09:40 AM
jwhitetail's Avatar
jwhitetail
I think alot of thing's were ironed out by 03, my harness was not loose at all, but i did it anyway, and checked everything over good. To Chunderdownunder, next mod is a 31 row 6.0 trans cooler, it should be here this week.
Old Jun 13, 2010 | 12:55 PM
guitarpicr's Avatar
guitarpicr
Mines an 02 - Anybody know if it would have the updated version clip? Hav'nt had any problems so far & I'm at 91K.
Old Jun 13, 2010 | 03:38 PM
F350-6's Avatar
F350-6
My 02 had the old harness in it.
Old Jun 14, 2010 | 07:15 AM
Robert6401's Avatar
Robert6401
jwhitetail,
How many miles are on your truck? I have been considering pulling the VC's to re-torque everything, but since I don't need to do the 50cent mod I have been dragging my feet. I would hate to go to all the trouble to pull the covers if there isn't anything under there that needs to be re-torqued.
Thanks.
Old Jun 14, 2010 | 07:30 AM
Kwikkordead's Avatar
Kwikkordead
I had to cut it that way because the quarter would have stood up and interfered with the valve cover.
Those little tabs limit how deep you can insert the quarter.
I was getting ready to change the name to the 25 cent mod, just cut one quarter in half and insert one half on each side.
Old Jun 14, 2010 | 10:05 AM
bama29fan's Avatar
bama29fan
i found out last week that my truck has the updated harness and retainers. would it still be beneficial to to the .25 mod?
I have been trying to build some history with/for my truck since iv'e only had it for about 8K miles of it's life. i called a dealer last week (that i found out did some work about 2 years ago) and they said the MAP sensor, valve cover gaskets, and harnesses were changed. that was at about 140K miles.
Old Jun 14, 2010 | 10:17 AM
mueckster's Avatar
mueckster
I would say that it would fall into the "it can't hurt" category.
Old Jun 14, 2010 | 10:46 AM
jwhitetail's Avatar
jwhitetail
Originally Posted by Robert6401
jwhitetail,
Thanks.
Robert, it has 123,000 miles. There was nothing loose under there, the torque wrench clicked right away, If your truck is a 03 and you do decide to do it cut the quarter down to half way to clear the valve cover.
Old Jun 14, 2010 | 02:45 PM
Robert6401's Avatar
Robert6401
I'm at 125,000 miles. I think I'm going to hold off on pulling the valve covers for now. I know that just because you didn't have anything loose doesn't mean that I won't, but free-time for wrenching is very hard to come by these days, so I think I should focus my efforts elsewhere.
THANKS!
Old Jun 14, 2010 | 03:55 PM
hammer65's Avatar
hammer65
My 03 had 138,000 on it when the left VC connection failed. Western Diesel in Cody Wyoming, diagnosed and repaired it for me. Jim
