Replacing AC Clutch
Old Jun 12, 2010 | 06:06 PM
Talyn's Avatar
Talyn
Replacing AC Clutch
Is this an assembly?
How does this work? Don't study stuff like this in all the HVAC classes I've had. heh.
I didn't have much luck with the search feature on here. Got lots of clutch threads and not much on replacing this thing.
Do I basically pull the pully off and replace it? *shrugs*
Mines boned.
Need to check the compressor too to make sure the bushings/bearings are not screwed as well. Just what I would want to replace.
Don't have any tools to redo the coolant either. DOH!
Old Jun 12, 2010 | 09:10 PM
oldbird1965's Avatar
oldbird1965
If you even think your clutch AND compressor are bad why not just buy another one? What's with the shoeless thing standing on a pile of dead babies?? lol
Old Jun 12, 2010 | 09:28 PM
Talyn's Avatar
Talyn
there not babies. haha. They are hobgoblins.
I don't think the compressor is bad. I just said I should check it and make sure.
I am asking about the clutch though.
Old Jun 12, 2010 | 09:49 PM
oldbird1965
I read about shimming the clutch on here someplace but that's about all the help I can be. OK, hairy little men who are fond of practical jokes??
Old Jun 12, 2010 | 09:58 PM
quesey's Avatar
quesey
i beleave you can pull the clutch and pulley.parts store should rent you the tools to do it.but i'm almost sure you'll lose all the coolant.i just replaced my compressor and it was cheaper to buy one with a new clutch than to buy it without out it.i just changed it out and recharged it with out pulling a vac on it works just fine just dont leave it open long
hope this helps
Old Jun 12, 2010 | 10:09 PM
Talyn's Avatar
Talyn
should always pull a vacuum on a system before adding coolant.
System wont pressurize properly. and air is a contaminate and bad on the pump.
Pulling a vacuum also gets out all the moisture and debris in the system that can damage components.
Old Jun 13, 2010 | 10:53 AM
fordpride's Avatar
fordpride
the clutch will come of with out the pully and you will not loose the coolant
Old Jun 13, 2010 | 02:22 PM
Talyn's Avatar
Talyn
Thanks Mike!
You shouldn't loose any coolant unless you unhook the lines anyways.
Taking a pulley off shouldn't let you loose coolant.
Old Jun 13, 2010 | 04:10 PM
TheTowingCowboy's Avatar
TheTowingCowboy
You wont lose any coolant taking the pulley off, and you are right on with te pulling vaccum.
Old Jun 13, 2010 | 06:53 PM
Talyn's Avatar
Talyn
Yea. Wan't sure why somebody would think you'd loose coolant taking the pulley off.
Old Jun 13, 2010 | 07:17 PM
TheTowingCowboy
IDK but then again you know as well as I do the way the build some stuff anymore they do stupid stuff.
Econo4spd
Jun 24, 2014 01:45 PM
gbeach
Jul 22, 2011 01:29 PM
rashanny
Feb 14, 2011 11:06 PM
V8Ranger302
1983 - 2012 Ranger & B-Series
Sep 22, 2010 10:57 AM
DieselFuelOnly
Apr 9, 2007 10:20 PM
