Sponsored by: Real Truck
Starting issues
Old Jun 11, 2010 | 03:35 PM
dlwhitesel's Avatar
dlwhitesel
Starting issues
Can anyone help my track down starting issues with a 99 F250 5.4 liter Super Duty? Periodically, there are times when it will not start unless you shift it into neutral. Most of the time it happens when the engine is warm but there have been times when it does it the first time you start it that day. When you turn the key the nothing happens so I don't think it is a starter issue, I am leaning towards the neutral safety switch or the solenoid starter but wondering what else I should check.
Thanks.
Old Jun 11, 2010 | 04:17 PM
gearloose1's Avatar
gearloose1
Check to see if the PCM is seeing the shift to Park.
