cab to frame mount kits
Old Jun 11, 2010 | 03:19 PM
sgettin's Avatar
sgettin
hello. i need new cab and radiator support kits for my 63 4x4 3/4ton. it appears 2wd is all thats available aftermarket. does anyone know if the 2wd are similar enough to work on my 4wd?. from the looks of things i could pbly make a kit but would be easier to buy them if they are available.
i did use the search button but obviously wasn't successful.
thanks for any advice.
scott.
Old Jun 11, 2010 | 07:42 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Take a look at the radiator support mounts...are there rubber cushions there? None are shown in the parts catalog illustration.
Front cab cushions for 1961/64 4WD: The parts catalog sez: Improvise from tire carcass.
It sez the same thing for the upper cushions for the rear cab mounts.
The lower cushions are: C1TB8100228A = cut to fit. The problem is, that these cushions are now obsolete, no one has any.
Garbz2 will know if 2WD parts can be substituted for 4WD's.
Old Jun 11, 2010 | 08:53 PM
sgettin's Avatar
sgettin
should have checked my cd, as is pbly typical i assumed a bit much. in any event i'm glad to hear i have to "improvise". that is the best part of my truck.
i do have some rubber bridge bearing pad that i can cut if need be so guess i'm covered on any thing that needs rubber.
thanks numberdummy.
scott.
sgc2c
Jul 13, 2017 06:17 PM
Hellwig Suspension
Ford Truck Parts for Sale
Sep 23, 2016 10:58 AM
Hellwig Suspension
Vendor Specials, Discounts, Product Announcements & Group Buys
Aug 19, 2016 01:31 PM
Aremee
Jul 26, 2016 09:57 AM
2012FordHD
2009 - 2014 F150
17
Nov 14, 2011 02:00 PM
