E40D Help, Fuse Blowing???
Old Jun 10, 2010 | 09:32 PM
93RangerXL4x2's Avatar
93RangerXL4x2
I have a 1994 F-150 300 Inline 6, and a damn fuse has blown 2 times today, which turns off the dogital odometor, doesitn shot the speed the truck is doing, and shifts hard, (non eletronic) please help!!! why is it blowing all of a sudden? it was a 15 fuse, should I try a 20 amp??? thanks in advance, dont want the E40D to burn out.
Old Jun 10, 2010 | 09:38 PM
White 97 xlt's Avatar
White 97 xlt
I'm willing to bet the wires to the OD off switch have broken... The reason I say this mine did the same thing almost 4 yrs ago..
The wires broke right where the shift lever connects in the column, took the plastic cover off and it was right there, spliced the wires and used heat shrink, it hasn't missed a beat in almost 4 yrs....
BTW, mine popped the fuse everytime I put it in reverse....
NO DON'T GO BIGGER ON THE FUSE!!!!!!!!
Old Jun 10, 2010 | 09:44 PM
93RangerXL4x2
Post
you mean the shifter, check the wires on the OD Button? any other takes?
Old Jun 12, 2010 | 10:19 AM
mprice's Avatar
mprice
Which fuse is it? Mine did the same thing when the cruise servo went bad. Don't go up to a higher rating..
Old Jun 12, 2010 | 10:29 AM
ymeski56's Avatar
ymeski56
Der Postmeister
The wires under the truck, back to the VSS.
