89 F250 2wd Windshield Wiper
Old 02-05-2003, 11:11 AM
Harlyred1's Avatar
Harlyred1
Harlyred1 is offline
Here we go........
I wanted a delay/ intermittent wiper control. I also needed to replace the switch anyways as it had no **** and only worked at hi speed. I got a 2fer deal on eBay for switches with the delay module. Playing musical chairs with the switches and modules, I get the wiper to work only occasionally, with no hi speed at all and a very sluggish operation in other modes. Using any switches ONLY, (without module) I still only get hi speed. Is it the consensus here that my wiper motor is screwed up? Thanks
Old 02-05-2003, 11:34 AM
kioolt's Avatar
kioolt
kioolt is offline
I don't know if this will help but check it out.
Interval Windshield Wiper System "E" Motor Test
Quick Check
1. If wipers operate in high speed only and wipers hesitate when going through PARK position, connect jumper wire from windshield wiper switch case to ground.
2. If wipers now work in low speed, repair switch ground.
3. If wipers do not work in low speed with switch case grounded, replace Wiper Control Module.
Old 02-05-2003, 12:49 PM
Harlyred1's Avatar
Harlyred1
Is the black module box supposed to be grounded as well?
Old 02-05-2003, 10:16 PM
steve83's Avatar
steve83
steve83 is offline
No, it's plastic. Its ground is in its wiring harness. The switch body (for interval wipers ONLY) has an extra ground wire riveted to the case that MUST be attached to a true ground.
Old 02-06-2003, 11:36 AM
tsheriff's Avatar
tsheriff
tsheriff is offline
My motor was bad when it would turn on and not turn off
n4gnr
12-21-2011 10:58 PM
JimLongusa
03-11-2010 12:11 AM
84-250
Electrical Systems/Wiring
08-07-2005 03:54 PM
rompin78
03-10-2005 12:52 PM
AManAndHisTruck
12-03-2004 11:27 AM
Quick Reply: 89 F250 2wd Windshield Wiper
