There is no nut kit required. That was for some other version of the Dana 50/60 front-end Ford (or someone else) used to use.
The front LOCKING 4x4 hubs are the same from 1999 through 2004. 2005 they changed the front end to coil springs, and used a new Warn-manufactured vacuum hub system that actually seems to WORK.
