1978 - 1996 Big Bronco
power window
Old Feb 5, 2003 | 05:00 AM
Dutch123's Avatar
Dutch123
power window
The 96 XLT driver power window does not go down. Toggle the switch apparently draws current as the battery guage demonstrates a tic ,tic. Door panel has been of but I'm stumped? ANy clues or keys toa fix?
Dutch
Old Feb 5, 2003 | 07:43 AM
spixican07's Avatar
spixican07
power window
my passengers side window was finicky when i trid to lower it from the driver's side button, but it worked from the passenger button. is it a button or a window?
theres a small switch box on the backside of your buttons. the wires were loose in mine so i jammed a washer down in the window one to make a more solid connection. seems to work pretty well.
if it doesnt work from either door, i would say that your operating motor was bad. go pull one from a junk yard in that case.
Old Feb 5, 2003 | 07:49 AM
steve83's Avatar
steve83
power window
If the volt gauge indicates that power is flowing, then the motor is bad. Remans are ~$80; junkyards get about half that.
Old Feb 5, 2003 | 09:01 PM
Bren4x4's Avatar
Bren4x4
Lightbulb power window
I had the same problem w/ my 92 xlt....both motors went bad about the same time.
I bought my 96 w/ a stuck window.
It's most likely the window motor.
I paid about 90 bux per motor from a local parts store.
You'll need to remove the outter door panel...which is only screws and plasctic retainer clips.
Next you'll need a good metal drill bit.....you need to drill 3 holes to get to the bolts that hold the old motor on.
take the two lower bolts out...becareful not to drop them into the door( I did )
cut the the wires on the old motor.
I found it easiest to remove the speaker...put my right arm down that hole to hold the motor...and use my left to remove the last bolt.
put the new motor in...with just the top bolt.....splice the wires...put the other 2 bolts back...not too tight and test it
from there it's just putting everything back
