Over-size valve info
Old Jun 8, 2010 | 06:28 PM
F-250 restorer's Avatar
F-250 restorer
S.O.B's! I just needed to get that off my chest. My own lack of research has come back--again--to bite me.
If you are going to install the over-size sbc valves in your head, listen up. SI Valves has the 1.94" intakes and 1.60" exhaust valves, designed for the 4.9 300, oe shaft diameter, tip, and length. They are the ones who sell them to Clifford Performance, so buying through SI Valves is cheaper than Clifford too (SI=$150 for the set, Clifford=$180).
These will not screw up the valve, rocker, p.rod geometry.
Also, in case anyone needs to know: 84 and older, the over-all valve length is 4.810". 85 and newer, it is 4.750". Don't let those different size valves bite you.
Old Jun 8, 2010 | 09:22 PM
adamtheman16's Avatar
adamtheman16
Ah..I have a 74 head, so I do have the longer ones. Maybe thats why my geometry isn't off far enough to cause any problems.
Old Jun 8, 2010 | 11:10 PM
F-250 restorer
Yep, after a little more research I found out about the different size valves. Mine are .095 longer, and with my rollers I need to get longer p.rods.
trozei
Nov 3, 2014 11:05 PM
KsCop
17
Jul 30, 2014 05:58 PM
mattthegreat
Oct 28, 2010 09:25 AM
F-250 restorer
Nov 15, 2009 12:58 PM
M6ride
Flathead V8 & Flathead 6
Jul 31, 2005 12:58 PM
