I am looking for cam and carb size recommendations for a 410.
on
I have a 410 in my 69 F100 4WD. It has the following:
I am looking for more mid and upper range performance. The truck has been very nicely restored and I am going more in the hot rod direction. It is a nice weather driver and not a working truck, so I am looking for reasonable drivability but with a decided preference for performance, including some lope at the idle. I am not too price sensitive as I have spent lots on her so far.
Looking for suggestions on cam type (roller?) and specifics (vendor, duration and rise), and what to expect/do about the vacuum. In fact, for those who have used more extreme cams, how do you deal with vacuum advance on the timing? Last, how much carb is enough?
I am happy to waste money on gas, tires, and cam and carb.
Thanks for letting me borrow your experience.
- Intake is a C6AE 9425-G (it also has 6F29 cast on the front of the intake, but I know with Fords you can lose your mind trying to figure out all the casting marks).
- Heads are C7AE-A
- Carb is an Edelbrock 600
I was recommended the Speed Demon 650cfm (Demon carbs flow more than their rating) for my healthy-built 390FE (shooting for ~450ish HP) in my 69 F100 build. It may give up 5-10hp (compared to a 750cfm) on the extreme top end, but it will gain it at lower RPMs where the motor spends most of it's life. Given the weight of the truck, this is a wise trade-off to maximize useable power.
on
Thanks for the suggestion about checking that the secondaries are opening, however I didn't mean it won't pull at all, it is just unimpressive and only marginally better than the 360 was.
I found the numbers for the current cam:
Lift .484-.510
Duration 270-280
Duration at .050 204-212
I'll investigate the Speed Demon carb.
Anyone else want to chime in?
Lift .484-.510
Duration 270-280
