Serious engine cleaner?
Old Jun 8, 2010 | 03:26 PM
Shooter00's Avatar
Shooter00
Parts solvent works best for me. I have one of the cheap flow-thru solvent brushes that the hose connection broke off of, so when I did the front end work the other day I dunked the brush and filled it with solvent out of the parts washer. Plugged the hole with the finger and ran over to the truck. Dumped it on the grease ball I needed to clean, little brush action and BANG! ShamWOW guy would be proud.
You can pick up a gallon of the solvent for around $13 at Northern T(F)ool or the like. Also makes cleaning under your fingernails a breeze!
00
Old Jun 8, 2010 | 03:43 PM
NBC-Steve's Avatar
NBC-Steve
I just had my engine and undercarriage cleaned by a detail shop for $125. It is spotless and I'm amazed on how clean they got it. If I did it myself it would have taken me a few hours and made a big mess plus all that gunk cannot go down the drain here in California. The stuff is considered Hazardous Material and could warrant a full Haz Mat clean up and I would be $$ responsible for.
Detail Shop!!
Old Jun 9, 2010 | 06:24 AM
Krump's brother's Avatar
Krump's brother
Originally Posted by ChaseTruck754
If that does it's job 1/2 as well as Kroil does it's job I'd bet it's some GOOD stuff!
I realized yesterday that I've made several posts hyping Kroil. Nothing is as good-at least nothing I have found.
tbruz
Jun 19, 2016 08:02 PM
iwlbcnu
Dec 9, 2014 07:49 PM
nineteensixt5f100
Aug 22, 2014 08:13 PM
Mike-fire32
401, 477, & 534 SD Engines
Jun 6, 2011 12:12 AM
sullyt28
Dec 12, 2010 12:28 PM
