I found the code??
Old Jun 7, 2010 | 09:08 PM
upnorthman's Avatar
upnorthman
I found the code??
My code that poped up was a cam shaft sensor code. Ford put a new one in under warranty 2 years ago. If it fails what happens???
Old Jun 7, 2010 | 09:16 PM
F350-6's Avatar
F350-6
If it fails your computer loses the timing signal from the motor and won't fire the fuel injectors. If you already had the recall done, the CPS costs about $25 from Ford. Takes about 5 minutes to change yourself.
Old Jun 7, 2010 | 09:56 PM
upnorthman's Avatar
upnorthman
Could the engine stopping and sputtering because of wayer in the fuel cause this???
Old Jun 7, 2010 | 11:14 PM
clintbonnie's Avatar
clintbonnie
You could put a extra hose onto your fuel bowl drain under the engine and drain the fuel bowl into a clear jar and let the fuel set for awhile. If there is water in your fuel, you will see it..
Old Jun 8, 2010 | 12:30 AM
SpringerPop's Avatar
SpringerPop
A bad CPS might make you THINK there's water in the fuel, but it's really all electrical.
Pop
