Where are the damn horns located on a 2000 SD?? I replaced the fuse and now all I hear is the relay clicking.
No Beep Beep and I wanna pass the little car ahead of me.
I actually would have bet the 2000 F350 horns were in the same location as mine. I helped a fellow a couple years back with a minor dent repait on the passenger fender and thought I had remembered seeing the horn in the same location.
Rick...
Originally Posted by MuncieV10
Rick, he asked about the 2000 SD; the 2000 F250 I had the horns were on the drivers side. I guess Ford moved them for the 2002 model.
Rick...
My 2000 was built in November 99; who knows, they may have moved them in the later build of the 2000 model.
After thinking about it some more the 2000 truck I was helping with was a mix of trucks after a couple accidents he had over the years with it. You could very well be correct about the horn location on the 2000.
Soneone will chime in to confirm correct location.
Rick...
