Will these headers fit?
Old Jun 6, 2010 | 08:49 PM
75F1004x4's Avatar
75F1004x4
Hello, My truck is a 1975 f100 4x4 with a 390 FE. I need a comformation that these headers will fit. Thanks
Hedman Hedders 89120 - Hedman Street Hedders - Application - SummitRacing.com
Old Jun 6, 2010 | 09:06 PM
akforceten's Avatar
akforceten
i got rid of my headers it wasn't worth it for me . for one had to pull passenger side header to replace starter plus the constance leaks plus on my f-250 4x4 highboy i didn't notice a difference so i converted back to stock manifolds now nice an quiet an i still have gobbs an gobbs of power . well thats my 2 cents
Old Jun 6, 2010 | 11:19 PM
Fordworth's Avatar
Fordworth
Yup, those are the right ones. I've had the same ones on my '75 for 13 years with no problems. In fact I run nothing but headers on my vehicles since my engines would probably choke and die with stock manifolds. It's true that you have to pull the right one to remove the starter but how often does that happen? The key to preventing leaks using good gaskets and keeping the bolts tight. Throw away the gaskets that come with the headers and get a pair of these fel-pro's.
Fel-Pro Performance Z1442 - Fel-Pro Performance Exhaust Header Gasket Sets - Overview - SummitRacing.com
Stage 8 locking fasteners are a good idea too.
Old Jun 7, 2010 | 12:56 PM
HIO Silver's Avatar
HIO Silver
Right motor mount
You'll have to pull the starter, unbolt the right motor mount, and jack up the engine to insert the header from below. On the 89120, two tubes will be forward of the mount and the other two tubes will be behind it.
Visit www.hedman.com , search the PN, and download the instruction sheet for a preview.
Old Jun 7, 2010 | 05:52 PM
75F1004x4's Avatar
75F1004x4
Hey thanks alot guys.
Old Jun 7, 2010 | 09:19 PM
HIO Silver's Avatar
HIO Silver
Encountered an issue!
75F1004x4.. you might want to subscribe to my new thread on installing the 89120s. 'Ran into a problem with accessing the motor mount bolts per Hedman's instructions.
https://www.ford-trucks.com/forums/9...need-help.html
Old Jun 11, 2010 | 11:42 PM
HIO Silver's Avatar
HIO Silver
It fits, sort of.
75F1004x4... see my thread (linked above) with new pics on the 89120s. 'got the headers installed but omigosh what a job. Still gotta reinstall the starter and clutch Z-bar tomorrow...I am beat.
PM me if you have questions.
Old Jun 12, 2010 | 02:08 PM
75F1004x4's Avatar
75F1004x4
Hey thanks, that thread will really help me out. My truck is also lifted 4-inches too.
