Brake Light Problems
Old Jun 6, 2010 | 08:28 PM
cajunhcm's Avatar
cajunhcm
Hi,
I just finished putting a signal stat 900 in my 1960 F-600. Question: Is the red light in the middle of the switch supposed to flash when the truck is running and the lever is in the neutral position? 2nd Question: My tail lights come on when i turn my lights on and my turn signals work on both sides, but when I push my brake pedal, the lights don't glow with or without the lights on. I have replaced the brake light switch and all of the wiring is brand new. Anyone have any suggestions?
Alex
Old Jun 6, 2010 | 11:14 PM
Julies Cool F1's Avatar
Julies Cool F1
Oh gosh a signal switch problem!!!!! Something new LOL!
The central red light on your switch should only light when your emegency flashers are activated. If they flash try pulling out (or pushing in) the emergency light ****.
WRT the brake lights, you have a wiring cross up. The brake lights and signals use the same circuit and are controlled through the signal switch.
The tail lights are a completely different circuit and are run out of your headlight switch. Here's a couple of diagrams:
Name:  Signal Switch Wiring.jpg
Name:  R F1Generic Light Wiring Diagram.jpg
The upper one should show your switch. The lower one is for my switch - an "Everlasting", but shoud give you an idea of the overall lights layout.
thatsrealnice
16
Jul 31, 2020 06:00 PM
Hwklein88
46
Nov 7, 2016 04:55 AM
forddriver78
Aug 26, 2015 08:03 PM
jakegypsum
Jan 9, 2014 02:47 PM
wulleebullee
13
Oct 26, 2011 09:19 PM
