cold engine squealxpkorer
Old Jun 5, 2010 | 01:18 PM
dubbz's Avatar
dubbz
I own a 2000 explorer 4.0 overhead valve. On cold starts I get a fairly loud squeal that goes away when warmed up. I've changed the serpentine belt, alternator, and both idler pulley and tensioner pulley. I don't think its coming from the compressor clutch. I'm leaning to maybe a sensor, I had a foghorn sound that ended up being the A/I sensor. Any help on testing the sensors for the squeal or any other thoughts would be appreciated.
Old Jun 5, 2010 | 10:33 PM
aquanaut20's Avatar
aquanaut20
Buried under the coil pack is the CPS (Cam position sensor), common for this to exhibit what you describe..
