instrument cluster ?
Old Jun 5, 2010 | 11:35 AM
64 hi-boy's Avatar
64 hi-boy
I have a 66 and it has the round cluster like 61-64 and I would like to have the other style like most 65 and 66's that is more horizontal. Can just change them out or will that work? Thanks Rod (and I dont know why this computer started printing this way)
Old Jun 5, 2010 | 11:59 AM
Bill W's Avatar
Bill W
Hey Rod, the Swept speedo takes an extra wire harness.... if you change your round one out you need the harness also, i think it goes to the alt gauge.
Old Jun 5, 2010 | 12:21 PM
garbz2's Avatar
garbz2
It will work however there is only one turn signal lamp in the sweep speedo, one lamp will flash under the dash. To ues the optional oil and amp gauge you need a separate harness that taps in to the existing harness. behind the dash and out on the passenger apron.
Garbz
Old Jun 5, 2010 | 06:58 PM
camperspecial65's Avatar
camperspecial65
While most of the sweep speedo clusters do have the optional alt and oil pressure gauges, they were just as garbz said...optional...but if you dont want the extra gauges its pretty much a plug and go...the additional t/signal light being one as mentioned above...if you want a sweep speedo cluster, I have a few of them...all have the extra gauges...
- cs65
Old Jun 5, 2010 | 07:45 PM
64 hi-boy's Avatar
64 hi-boy
Thanks alot guys your help is valued alot it dont sound to major of a change , when it comes time to change it I'll get ahold of you cs65. Thanks again Rod
52' fordnut
Dec 12, 2014 07:34 PM
Shadowrider123
Nov 15, 2014 09:18 PM
jav409
May 5, 2010 07:37 PM
Dads 66
Sep 12, 2005 11:58 AM
robbobvilla
Nov 17, 2001 08:44 PM
