brake controller info
Old Jun 4, 2010 | 10:46 AM
bumblebee902's Avatar
bumblebee902
my truck supposidly came with a tow package or camper package. there are brackets on the frame for where a fifth wheel hitch would bolt to, holes are drilled in the box and there is a round 7 trailer connector mounted to the inside of the box on the drivers side. there was also a round 7 connector at the rear of my truck but that one is spliced into the wiring harness. there was no hitch installed at the rear.would my truck already be set up to install a brake controller using factory wiring? thanks
Old Jun 4, 2010 | 10:59 AM
Archion's Avatar
Archion
Veteran: Marine Corps
Look under the dash to the left of the sterring column, should be a short three wire pigtail.
