03 limited overhead console not working
Old Jun 3, 2010 | 09:51 AM
Signalman SM2's Avatar
Signalman SM2
The air works but the display is not showing anything, blank, dead. Any suggestions?
Old Jun 3, 2010 | 10:24 AM
Signalman SM2
Never mind. I just learned how to search past threads. This site really is cool.
John
Old Jun 6, 2010 | 09:53 PM
sierra6's Avatar
sierra6
fix or replace display
Although is is possible to repair them a new one will cost $200.
Some one previously posted a repair if you want to try.
I purchased a new one from Ford.
On My overhead console there was one Phillips Screw to remove and then starting in the back pull the console down. It is held with spring clips. You will need a TORX T10 screw driver to remove the display form the overhead mount.
Disconnect the electrical connector. Fix or replace display. Reverse to button it up.
In your owner's manual are the instruction on how select the correct region magnetic north correction factor and how to calibrate the compass.
Old Jun 15, 2010 | 05:42 PM
Signalman SM2
Thanks for the info
I've seen the screw and will work on it over the summer.
