E40D gasket
Old Jun 2, 2010 | 10:10 PM
powerstroker100's Avatar
powerstroker100
E40D gasket
So I call my local dealer for a reusable gasket since I am not a fan of the cork, and the parts guy says that apparently my transmission pan only uses a silicone to seal it? lol wtf I'm thinking so in short does anybody have a part # for this reusable gasket? If I remember it is really for the 4r100 but theyre somewhat similar to e40d
Old Jun 2, 2010 | 10:48 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
i got mine at napa when i flushed the trans.it came with the filter for like 45 bucks or so.kinda pricey.
imho if your going to replace it,then now is the time for a flush/filter anyway.
its recommended every 30k.
Old Jun 2, 2010 | 11:16 PM
powerstroker100
yeah thats what I have setup for this weekend is doing transmission service do you use an additive for the tranny fluid?
Old Jun 2, 2010 | 11:25 PM
powerstroker100
if anyone knows what size bolts are used for the tranny pan please speak up I'm missing two of them hoping this is just somthing I can grab at HD
Old Jun 2, 2010 | 11:26 PM
87crewdually's Avatar
87crewdually
Don't forget to pull the grommet in the bottom of the bellhousing and remove the plug for the torque converter to drain it also. Usually good for another few quarts of old fluid. Just thought I'd post it for anyone that didn't know.
So you know for sure, pull another bolt and match it up to not only diameter and thread pitch but also length. Don't be surprised if they are metric.
Old Jun 2, 2010 | 11:48 PM
powerstroker100
thank you for reminding me, now odds are the flywheel wont be lined up to reach the drain plug do I need a special tool to rotate it?
Old Jun 2, 2010 | 11:51 PM
87crewdually
Usually I just bump the key until it lines up. With the fuel solinoid unplugged at the injection pump so it won't start of course.
Old Jun 3, 2010 | 12:40 AM
peruses's Avatar
peruses
i use a big screwdriver on the gear teeth on th flywheel, slow but safe
Old Jun 3, 2010 | 08:50 PM
FORDF250HDXLT
also,now would be a great time to install a shift kit.
they are great because they make the trans shift firm and quickly into gear.this does two things.
1.it reduces friction thereby reducing heat.
2.it firms the shifts and doesnt waste energy while hauling loads.feels really good btw while hauling.she sets ya into the seat a bit between shifts.does so when you come onto her empty too. by shifting into gear and engaging the clutches quicker,rather than letting them "slush"/"slip",it means your clutches last longer.
its kinda time consuming,and you need to be careful not to lose anything but WELL worth the hassle.
i really enjoy the b&m shift kit with the stage 1/hd install.
something to consider.
i used Mark Kovalsky 's (he's an retired and or ex ford trans tech engineer) method.even though i had a TC drain plug,and it worked great! there's a guide by him here.but i still havn't figured out how to search and find the tech guides so i can't seem to find it.
Old Jun 3, 2010 | 09:00 PM
powerstroker100
Anything that will make the transmission last longer I'm all ears, is this what you are talking about http://trickshiftperformance.com.au/...hift%20kit.JPG if so what are all those metal and gasket looking things and how hard is this to install
Old Jun 3, 2010 | 09:14 PM
FORDF250HDXLT
yes.thats exactly it.
there are more advanced ones,but unless your going to pull the trans to install the other parts,that's the ticket right there.
the instructions make it pretty simple to understand.whats such a PITA is,there are check ***** and springs etc that you need to be careful of,and drill(and then wipe very clean) a few holes.
it's not hard to understand and follow though.just careful,time consuming steps.soooo worth it though.id do it over again in a heart beat.
i put one in a c-6 years ago too,so i knew what i was in for.dont be scared to do it yourself.just plan on a couple hrs going slow thats all.
this will help too if you loose your ***** lmao:
https://www.ford-trucks.com/forums/8...our-*****.html
you'll be so happy if you do this,and be thanking me like crazy latter.
i kinda wish i set that spring and screen into place before i took that pic(see them in the upper left,in the tray?) but in the instructions there is a pic.those parts are clear anyway.the check ***** where not(its like way to dark to see them.)so between the two,you'll have it made in the shade.
lupuseven
Dec 5, 2013 12:27 PM
swirlparanoid
2004 - 2008 F150
Sep 15, 2010 08:06 PM
powerstroker100
46
Jun 7, 2010 02:19 AM
powerstroker100
May 17, 2010 08:16 PM
scoosty
Jul 23, 2001 09:05 PM
