351m timing gears?
Old Feb 4, 2003 | 11:18 AM
dillon1033's Avatar
dillon1033
351m timing gears?
i just recently installed timing chain and gears in a 351m .i wasnt sure what model the motor was so i guessed 78 i thought all 351m/400 timing chain and gears were 100% interchangable but when i got mine home and tried to install the gear on the crank it was the wrong size and the timing marks were different did fford change the crank dimensions ? where do i find casting #on block?next to sending unit it says 4g31
Old Feb 4, 2003 | 12:35 PM
Brian S's Avatar
Brian S
351m timing gears?
Check the part number. I'll bet they sold you one for a 351W.
Casting # is behind the starter to the left of the feeze plug.
The other # is the casting date. 4G31='74 July 31
