Door code 03 Excursion
Old Jun 2, 2010 | 07:28 PM
Signalman SM2's Avatar
Signalman SM2
I've been looking for this thing for a while. I pulled the radio and used a flashlight to see what I could of a white sticker with a bar code and some letter number combinations, the sticker is well hidden. You can only see part of it after removing the radio. I had a feeling about this one. Its an 03 limited. The sticker is facing you but on a plastic box behind a metal pipe, that has been welded. I used a small mirror to see more of the sticker that was hidden from view. I wrote down the numbers and it did not work. Then (stupid me) realized the numbers were reversed in the mirror. I reversed them and it finally worked. It is a five digit code. The radio bracket, wiring, and that darn metal pipe keep you from seeing this rather large sticker.
Hope this helps someone,
John
<!-- / message -->
<!-- controls -->
Old Jun 2, 2010 | 07:58 PM
alloro's Avatar
alloro
Not likely since this is the Expedition and Navigator forum, not the Excursion forum.
Old Jun 4, 2010 | 12:39 PM
Signalman SM2
Clicked the wrong link I guess. No biggy
