Sponsored by: Kumho
alignment after lift?
Old Feb 4, 2003 | 09:55 AM
Starratt04's Avatar
Starratt04
i just put a 4 inch lift on my 1999 f-250. it has a solid axle and leaf springs up front.do i need to get an alignment on the front? ive drove it about aweek and it is really smooth
Old Feb 4, 2003 | 05:00 PM
Yeti's Avatar
Yeti
No alignment is necessary, about the only thing that needs adjustment is re-centering your steering wheel.
Old Feb 4, 2003 | 10:39 PM
Motoxman_117's Avatar
Motoxman_117
Yeti, I you know a heck of a lot more than me but i was just wondering if he did the lift and his axle tilted more one way or the other by angle of the spring where it mounts to the axle wont it change the toe in of his alignment? Just curious because mine changed a little bit when i put the fabtech lift on my truck according to the dealer which used a laser aligner. I could be wrong though and if it was off i am sure only a very small amount.
Lee
Motoxman_117
what the H@$%
Motoxman_117
damn thing said server busy and posted my question 3 times.
Old Feb 5, 2003 | 06:47 AM
Yeti's Avatar
Yeti
Not with only a 4" lift, really doesn't affect anything. If you go 6 or more then maybe you would have a slight toe issue.
When I finished my 8" on my 01, I checked my axles for square and even put it on my scales to see if any of the corner wieghts changed. Other than the extra wieght of the parts everything stayed the same. I suppose if I didn't have my shop, I would of taken it somewhere to have it checked, but in my opinion, I just don't think 4" will throw the tow off enough to worry.
Now with a 1/2 ton or older ttb f250, definetly get a alignment!!
Old Feb 5, 2003 | 03:04 PM
Starratt04's Avatar
Starratt04
yea thanks alot. yea i just adjusted my steering wheel the other day. it was pretty simple to do.
Old Feb 5, 2003 | 06:10 PM
Yeti's Avatar
Yeti
Just keep an eye on your wear pattern , but in my opinion you should be fine.
Old Feb 6, 2003 | 09:39 AM
pbrstreetg's Avatar
pbrstreetg
Hi-
Yep i agree with all ya's. Remember on leaf sprung solid axle suspension the toe is really for all practical purposes the only adjustment that can change once it's setup. Camber won't change unless something bends nor is it adjustable, and caster can only be changed with angle shims on the axle pads.
strickland
2015 - 2020 F150
Aug 6, 2015 10:12 AM
Harley250SD
6.4L Power Stroke Diesel
Nov 8, 2013 07:42 PM
ikkaruss
16
Sep 29, 2012 12:19 PM
oldbluebronco
1978 - 1996 Big Bronco
17
Apr 16, 2009 06:37 PM
wyoguy
Apr 5, 2006 05:33 AM
