2003 4x4 Ranger bolt torque
Old Jun 2, 2010 | 12:03 PM
Grumpy1946's Avatar
Grumpy1946
My right front wheel bearing has turned to dust (literally). I can move the top of the wheel almost 1/2 inch in & out. I have the new hub but want to check on the proper way to torque bolts on Fords. I've been messing with IH tractors and Scouts mostly the last few years. IH specifies bolt torque with lubricated threads and their numbers are maybe 60% of what I see on comparable Ford bolts. I know I read a few years ago (maybe 10-15, that's not long) that Ford specifies bolt torque with clean dry threads.
Is this still the case? Can anyone confirm this?
Thanks!
Old Jun 2, 2010 | 01:29 PM
g_k50's Avatar
g_k50
2001 Service Manual states 162 lb-ft (220 Nm) for the nut and washer assembly on the wheel hub.
9 lb-ft (12 Nm) on the dust shield.
80 lb-in (9 Nm) on the anti-lock sensor.
85 lb-ft (115 Nm) on the CV joint and boot cover bolts.
Discard the nut and washer assembly on the wheel hub. I guess this means you have to use new nut and washer assembly, I suggest you get one from Ford.
I'm also assuming clean dry threads.
Old Jun 2, 2010 | 02:30 PM
Grumpy1946's Avatar
Grumpy1946
Thanks for the info!
I got a new nut when I got the hub. Parts guy was very careful to tell me that this is a "Torque to yield" nut. Like a head bolt or flywheel bolt on a 7.3. You tighten it till you just cross the yield limit. Don't miss on the torque.
Wonder why they used a nut like that on the hub?
Groundpounder0331
13
Jun 23, 2025 02:18 PM
joehd8811
General Diesel Discussion
Oct 15, 2015 12:04 PM
Crewcab Turbo
Sep 4, 2015 10:56 AM
Augy88066
Feb 15, 2015 11:24 AM
los341
6.7L Power Stroke Diesel
24
Jun 15, 2014 10:20 AM
