Injector O-rings
Old Jun 2, 2010 | 06:35 AM
serviceguy's Avatar
serviceguy
Injector O-rings
The other day my truck seemed to start making oil so I am either about to be very rich or very poor. I suspect my injector o-rings are shot 219k go figure. My question is, is their any other ways fuel can get in the oil, besides a hole in a piston? Which I don't have any extra blow by when I took the cap off the filler neck and checked it. Also is their anything else that I should check or do while I have the injectors out? I ready changed my glow plugs and did the 50 cent mod this winter. Got new o-rings and 6637 kit on order with Clay last night.
Old Jun 3, 2010 | 09:08 AM
serviceguy's Avatar
serviceguy
Am I spot on here guy's or do I just smell funny or something ?
Old Jun 3, 2010 | 09:28 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
You said your truck SEEMS to be making oil. How do you know this? Is there someone around you that has an AE to do test? Is any smoke coming out the tail pipe. Can you do a compression test on the cylinders?
Old Jun 3, 2010 | 09:31 AM
shacks87's Avatar
shacks87
Sounds like your headed in the right direction. I'm sure others with more experince will chime in soon.
Old Jun 3, 2010 | 09:34 AM
Kwikkordead's Avatar
Kwikkordead
Is the oil level actually rising?
And does it smell like diesel fuel?
serviceguy's Avatar
serviceguy
It went from using a quart every 2k or so to staying full for 3k and it's a nice golden brown instead of black and smells like fuel.
Old Jun 3, 2010 | 09:52 AM
miller_feed
The oil going to the injectors has a lot more pressure then the fuel going to the injectors. I would do a compression test.
Old Jun 5, 2010 | 09:48 AM
Kwikkordead
Yeah, this really has me thinking on where it could be coming from.
A cracked injector cup will send it into the coolant.
And something wrong inside an injector will send oil into the fuel, not the other way around like is happening here.
Is there possibly a port plug under the valve cover that is on the fuel rail and it's possibly loose and leaking?
Old Jun 5, 2010 | 10:15 AM
miller_feed
An injector leaking fuel and getting by the rings?
Old Jun 5, 2010 | 10:20 AM
cps's Avatar
cps
If you could get an oil analysis done you could determine fuel % in your oil to know if your o-rings are need replacing. Cheap to get done.
Old Jun 10, 2010 | 11:15 AM
serviceguy's Avatar
serviceguy
Ok guy's been away for awhile had some family issues crop up. Here's may plan of attack, I am going to change the oil rings and take a hard look at everything and do a compression check while I am in there, I am not sure what oil I used last so an oil test isn't going to tell me everything I would like to know so I am going to get a kit change the oil after I change the orings and send it in for testing after 2,000 miles and see where I am at. Yes the oil is under greater pressure when the engine is running but not at startup, I don't have any smoking it does seem to take more cranking to start.
