Ignition/elecritical problems
Old Jun 1, 2010 | 09:51 PM
floridamudder88's Avatar
floridamudder88
Angry Ignition/elecritical problems
Just picked up a 1990 f250 with a 351w. I test drove it and it ran fine, drove it home (about 35 miles). When I drove it next it started up and ran fine, tried to start it again but it just kept trying to crank but nothing. Hooked up a spark tester and tried cranking it, nothing happened until I turned the key back. I replaced the ignition coil and still doing the same thing. Maybe a relay problem? It seems like something gets hot and it doesn't wanna start. Any help? I'd appreciate it greatly.
Old Jun 2, 2010 | 09:28 AM
Franklin2's Avatar
Franklin2
Is this fuel injected? If so I would pull the codes and see what you get. Here's a site that tells you how to do it. Ford Fuel Injection. If you just want to throw parts at it, and you didn't have spark, I would replace the ignition module.
Old Jun 2, 2010 | 10:29 AM
floridamudder88
Alright thanks, I'll try to pull some codes and see what that tells me.
Old Jun 2, 2010 | 01:17 PM
powersmoked's Avatar
powersmoked
what do you mean"nothing happeneduntili turned the key back"?............maybe it is your ignition switch?
Old Jun 2, 2010 | 08:21 PM
floridamudder88
It tried to start but no spark until I turned the key back, as if it were discharging or something
Old Jun 4, 2010 | 09:08 PM
floridamudder88
It turned out to be the EEC:[ I finally had to take it to a shop..
Larry00663
May 11, 2014 09:15 PM
Dirt Racer96m
Apr 15, 2014 11:44 PM
floridamudder88
Jun 2, 2010 11:48 AM
starmilt
Nov 18, 2008 05:39 PM
idratherbedriving
Aug 9, 2004 09:42 AM
