what to do now
Old Jun 1, 2010 | 07:18 PM
acs2741's Avatar
acs2741
what to do now
i have a 2000 f250 with the 7.3 in it.I was driving when it completely shut down on me it threw the cam sensor code and icp sensor code so i replaced both of them still no start. I checked for codes again and it gave me code 1280 which is icp sensor out of range low . Can anyone out there give me any idea on what to try.
Old Jun 1, 2010 | 09:08 PM
F350-6's Avatar
F350-6
Does your wait to start light still function normally? If you're getting a P1280 code, what are you using to pull the codes? If it's a tuner, set the truck back to stock to rule that out. Then try unplugging the ICP sensor and trying to start to see if that helps.
Old Jun 1, 2010 | 09:11 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Unplug the ICP sensor then try starting...you may need to replace the harness.
Old Jun 1, 2010 | 10:00 PM
acs2741's Avatar
acs2741
Yes the wait to start light still functions normally i am using edge evolution tuner to pul the codes. It is stock right now i tried unplugging the sensor the other day still no start.
What would it take to replace the harness and do you know around about what it would cost me. This has really gotten me stumped .
Old Jun 1, 2010 | 10:51 PM
firestroker8706's Avatar
firestroker8706
Try unplugging the Edge. I have one as well and sometimes I have to pull it off to get things working properly. Plus it's just easier to eliminate that as one of the possiblities before you go spending money.
Old Jun 2, 2010 | 08:10 AM
00Dave's Avatar
00Dave
No disrespect meant, but I would suggest checking your fuses under the dash as well as under the hood. Just to be safe.
Old Jun 2, 2010 | 08:53 PM
acs2741's Avatar
acs2741
Ok will do thanks for the thought
Old Jun 5, 2010 | 10:26 AM
firestroker8706
Have you figured out the problem yet? It nice to hear feedback.
