Real life info needed on gear swap and MPG.
Don't overlook JL's advice about load, especially when towing.
The best mileage I ever got in my 99 was a run between Amarillo and Albuquerque at 85 mph. My rpm's hovered around 3000 the whole way with my 4:30's and I still got 13.5 mpg.
A revving engine works easier and the gas converting to energy is most efficient at the torque peak rpm.
That doesn't make sense. It would be easier to tow at 65 or higher with the 4.56, not the 4.30. It would be even easier to do it with the 4.88 gear.
Go with the gears, 4.30 with your current wheel/tire combo. It won't change the speedo.
That was one of the very few times I drove the '99 that fast for that many miles. West Texas and eastern New Mexico is like the autobahn to me.
I had a 00 Ford Excursion V-10 with 4.30 gears (factory) and I was able to get 15 sometimes 16 mpg with the cruise set at 62 mph on flat expressway empty not towing. Towing my 9K TT I was getting 7 mpg-9 mpg depending on conditions. I found at 70 mph with OD on the engine seemed to be right in its torque band and I could handle small hills without downshifting. Now I have a E350 V-10 with the 3.73 gears and towing the same trailer it has to be relatively flat to hold OD and with any wind or incline I have to take it out of OD.
that may be the case but no matter how you look at it the 4:56 gear will turn more rpm at a slower speed then the 4:30 making it easier to pull in overdrive at a slower speed,with my truck and (camper-9000lbs) I can pull up over pretty decent hills in overdrive at 65mph if I drop down to 60mph then the truck shifts out of overdrive,now if I had the 4:56 gears (which I wish I had)I should be able to pull that same hill in overdrive but at 60 mph because the deeper gear would turn the same rpm as the 4:30 needed to hold overdrive at the lower speed.I never mentioned anything about which gear would be running at peak power in overdrive because that may not always be possible in overdrive.PLAIN AND SIMPLE THE 4:56 WILL HOLD OVERDRIVE AT A SLOWER SPEED BECAUSE IT'S TURNING MORE RPM ok I'm done with this now, back on topic
#29
#30
In my '99 Scab 2 WD stock tires, I changed the 373's for a 430 Posi Rear end. I debated 410's vs 430's but I'm very glad I went for the 430's. While the RPMS are slightly higher especially when not towing there isn't a big hit in mileage. Towing, the 430's hold OD longer and thus I get better milleage with the new gears over the old. I tow a 7500# travel trailer. FWIW my speedometer reads correctly after the change. I also had a tranny temp gauge installed at the same time so I could keep an eye on it when towing.
If you are going with bigger tires I would consider 456's, but for me and my purposes, the 430's work very well.
