Frame Repair question
Old Jun 1, 2010 | 11:57 AM
jmm's Avatar
jmm
Is it ok to cut a section out of the frame and weld in a mild steel plate of the same thickness?
Old Jun 1, 2010 | 01:29 PM
Deluxetruck's Avatar
Deluxetruck
As long as it's in the side of the frame and not the top or bottom lip you'll be fine.
-Jared
Old Jun 3, 2010 | 10:43 AM
worldwideautohelpinc's Avatar
you can actually cut out any portion you'ld like. just MAKE SURE that the frame is BRACED properly before you cut. You don't want the frame to move at all!!!!
Old Jun 3, 2010 | 12:46 PM
HIO Silver's Avatar
HIO Silver
Avoid 90-degree corners. I drill the corners then cut out the bad section by connecting the "dots". Bevel the edges of the replacement piece and area to be welded for <B>maximum</B> weld penetration.
Old Jun 4, 2010 | 03:43 AM
wdfp's Avatar
wdfp
X2 on the 90 degree corners, and you can put a sleeve inside if you need to also
mgargiullo
Sep 12, 2019 10:30 PM
pengyou
May 31, 2015 06:07 AM
k_brenner
Aug 13, 2013 10:02 PM
DightonFord
1947 and Older Ford Trucks
Aug 28, 2002 09:21 PM
