Differential Gears??
Old May 31, 2010 | 10:19 AM
itsbajatime's Avatar
itsbajatime
I wanted to know if most or all SRW 7.3's came with the same differential gears. If so what are they. I have a 00' F250. With that in mind, I just installed 38.5's and wanted to know if changing those gears would increase my fuel mileage at all??
Old May 31, 2010 | 11:35 AM
F350-6's Avatar
F350-6
Your F250 should have 3.73 gears. Getting new gears will help many things, but don't look for any huge improvements in MPG's. Have you re-calibrated your speedo yet? Incorrect settings will give you false odometer and speedometer readings so you can't calculate mileage.
Old May 31, 2010 | 11:57 AM
itsbajatime
no i havent recalculated it yet..but i know it wasnt getting the greatest MPG before i put the tires on...what is a decent gear to run but wont kill the MPG too much
Old May 31, 2010 | 12:03 PM
Mat J's Avatar
Mat J
What are you guys using to correct the tire size, mine is far off with the 41s.
