Motor Switch
Old May 30, 2010 | 04:40 PM
Flasheroo's Avatar
Flasheroo
Motor Switch
This is a problem I need an answer to quick or I am going to lose this deal on this engine.
I have a 1967 F150 352 original motor and 3 on the tree and I the motro needs a rebuild badly.I have the chance to get a rebuilt mildly hopped up
1976 360 cheap with a lot of bolt on perfprmance parts.
Will this motor bolt up to my original 3 speed tranny or do I need to change the bellhousing and motor mounts?
Any help will be greatly appreciated
Thanks a Bunch
Flasheroo
Old May 30, 2010 | 04:48 PM
jowilker's Avatar
jowilker
Thanks a Bunch
Flasheroo
Direct bolt hole swap. You may have to add pilot bearing to the crankshaft if it is from an auto other than that it is a piece o cake.
Why don't you buy the complete truck and get the power steering and power disc brakes for about the same money.
Do grab the drivers side engine perch too, in case you do go with power steering later you wont have to swap it out later.
guluk
John
Old May 30, 2010 | 05:27 PM
Flasheroo's Avatar
Flasheroo
Motor Swap
John thank you for getting back to me so quickly.Only the engine is available and thanks to you sir it looks like its mine.Also thank you for the pilot bearing tip.
Take Care and Remember our military today!
Flasheroo
