Sponsored by: Kumho
65 F600 same brake problems
Old May 29, 2010 | 03:55 PM
Troublecreek's Avatar
Troublecreek
Same truck and the same ill-fated brake system. While trying to track down the problem of the brakes locking up, I pulled the master cylinder off to look and see if it had a check valve or not. It didn’t, however I did find a lot of fluid in the dust boot, although I’m sure one thing has nothing to do with the other. So I went to return it for a replacement and they new of all the issues I’ve had with the brakes so the owner said to bring in the hydrovac and that they would replace it as well. So at that point I decided to replace the rest of the steel lines and blew out and flush the entire system. Anyway, to get to the point, I was starting to bleed the system when I noticed the fluid coming back through the master with a steady stream almost shooting up and out of the cylinder. Just a guess but I’m thinking another bad master cylinder. The fun is truly fading fast on this thing…….
