2000 e-150 steering bump
Old May 28, 2010 | 05:18 PM
mammothmark's Avatar
mammothmark
Question 2000 e-150 steering bump
Need some help. My 2000 E-150 has had the ball joints, radius arm bushings and tie rod ends replaced - drives fine, the tires are wearing perfect but I have this "bumping" sensation, over small and large bumps, that is felt in the steering wheel. The movement is perceptible only in town at lower speeds. I have not replaced the pitman arm as my front end shop that did the work says "it's a non-wear item." The shocks are all good (bilsteins) so this is not an issue. ANY suggestions would be greatly appreciated.
Old May 29, 2010 | 03:55 PM
gearloose1's Avatar
gearloose1
Check tire pressures, lower it to minimum recommended for your load and see what happens.
Old May 29, 2010 | 04:40 PM
mammothmark
I've played around with tire pressures and it has had no effect.
