Carb Question
Old May 28, 2010 | 01:59 PM
birdhaus's Avatar
birdhaus
Carb Question
I'm considering retiring my tired old 2 bbl on my '65 352 and replacing it with a Holley 2 barrel 500 CFM / manual choke unit. Anyone have any sage advice about this move. Is it up to the task? I'm looking for a smoother throttle response and not necessarily a power boost. Its already overpowering the 3 speed tranny and rear end...
Thanks ya'll
Old May 28, 2010 | 02:09 PM
gritsngumbo's Avatar
gritsngumbo
That works very well on a Y-Block. Not sure about the 352, but I would think it would work fine, but we'll wait for someone with more knowledge of the 352 engine's fuel needs.
Old May 29, 2010 | 08:46 AM
JimKoz's Avatar
JimKoz
If you're talking about the Holley 2300, part number 4412, that's a high-performance carburetor meant for circle-track racing where the rules limit you to a 2-bbl carburetor.
For a truck engine driven on the street, I think you'd be happier with part number 7448 instead. It's only 350cfm but that's generally more than enough under 4000RPM. For idle quality and low-rpm throttle response, a small carburetor is hard to beat.
Old May 29, 2010 | 12:03 PM
gritsngumbo
I stand corrected. I was only looking at 2 bbl. Didn't think too much about the 500 cfm.
Old May 29, 2010 | 01:44 PM
camperspecial65's Avatar
camperspecial65
Personally I would stick with the Autolite 2100... mine works pretty good for me...cold blooded like always and also like every other Ford carburetor Ive ever had.
just my .02 cents...
- cs65
Old May 29, 2010 | 11:17 PM
Raider50's Avatar
Raider50
Well i put that exact carb on my 352. It was 8 months between carbs so i can not say for certain, but the seat of the pants feels like it picked up alot on the top end.
I figured out how to get the fuel line and vacume lines to work. And i had to lightly modify my throttle cable. It was the the first part swap i had ever done and it didnt take me more than an hour including the time finding the right sockets and wrenches. It was very easy.
I was disappointed that it was supposed to be a bolt on and go deal, but it still has a dead spot in the throttle right off idle. Other than that response increased slightly over the mid rpms and picked up a lot on the top end.
Old May 29, 2010 | 11:57 PM
birdhaus's Avatar
birdhaus
Hey, Thanks Fellas. I'll report back on this post after a couple weeks. Leaving the country on Tuesday for for a bit and will hop on this when I return. All good info, love to hear your experiences.
