460 balance
Old May 28, 2010 | 01:02 PM
gbrett's Avatar
gbrett
460 balance
I have a 460 short block I'm peicing together for my bronco its a D9TE and 3Y crank so I know its external balance my question is do I need the front weight as well as weighted flex plate or is the front weight just when you run heavy rods and where is a good place to source the front weight
Old May 28, 2010 | 04:17 PM
littlehusky's Avatar
littlehusky
you need it.
any rod you run with the exception of aluminum is not going to be lighter than the factory rods.
