iac valve question?
Old May 28, 2010 | 12:53 PM
Danger_Dave's Avatar
Danger_Dave
iac valve question?
idle air control question. i have read the treads about it, and it seems like i might need to pick up a new one and slap it in. i have cleaned mine out and it didnt seem to help. everything works totally fine unless i turn the a/c on. this is when the idle surges to like 2000 rpms and its a royal pain to try and drive and shift. i used to have a low charge and it was cycling the compressor causing some idle surges, but i have fixed that. is there a troubleshooting procedure for this little valve?
to me it all just boils down to having a computer controlled fuel injected nonsense vehicle! they claim to run better than the older vehicles and they never do, nor are they ever easy to fix. the check engine light never even comes on.
oh and also i get some overheating when its acting up. i believe part of the iac job is to adjust the idle and regulate a different amount of air flow during hotter conditions.
Old May 29, 2010 | 09:21 AM
pawpaw's Avatar
pawpaw
Sounds like the IAC is acting out, with the A/C idle up problem.
Look in the "Tech Info" thread atop this forum for some IAC trouble shooting ideas.
The over heat problem with the A/C on, is likely something else.
Maybe a fan clutch problem, thermostat, clogged cooling system, partially collasped radiator hose, slipping serp belt, plastic bag, bugs, or other debris restricting air flow through the A/C condenser & radiator fins, wrong coolant to water ratio, ect, ect, so maybe have a close look under hood at the cooling system things.
Old Jun 21, 2010 | 08:29 AM
2pd519's Avatar
2pd519
Dave did you change the IAC and did it fix your problem
Old Jun 21, 2010 | 08:41 AM
Hank85713's Avatar
Hank85713
I disconnected the IAC on my 94, adjusted the stop to pick up he rpms and have not had any issues. We trouble shot the system and it has a short in the wire bundle someplace so that why I did what I did.
Idles at around 750 rpm with ac on or off.
Old Jun 27, 2010 | 02:45 PM
Danger_Dave
2pd yes i changed the iac from advance auto parts, but unfortunately it did not fix the problem, so i then took it back to the store haha. its so intimidating when you open the hood of these newer cars with all the bells and whistles. i am going to invest in a book. the idle surges to 2000 rpms only if i run the a/c. without the a/c running the truck runs fine.
if i disconnect the connector on the a/c compressor the idle surges to 2000 rpms at all times while driving. my guess is something that tells the truck to increase the idle only a little bit with the a/c on, is going haywire
johnsmith8369
1997 - 2003 F150
13
Feb 10, 2011 07:07 PM
JFlom77
Feb 23, 2010 01:00 AM
wolverine382
1997 - 2003 F150
Apr 21, 2009 10:13 PM
jemini
Nov 24, 2007 08:25 AM
jcstratt
1997 - 2003 F150
Jan 31, 2006 11:28 PM
