tire size
Old May 28, 2010 | 08:33 AM
andyj ford driver's Avatar
andyj ford driver
tire size
i have a 1995 ford f150 that is completely stock and i was wondering what is the biggest tire size i could fit
Old May 28, 2010 | 08:39 AM
Conanski's Avatar
Conanski
2wd or 4wd?
On a 4x4 32's will fit with some minor rubbing while I think you're limited to 31's on a 2wd.
Old May 28, 2010 | 08:54 AM
andyj ford driver
i have a four wheel drive and would like to run 33's with maybe a little cutting
Old May 28, 2010 | 09:47 AM
slhf150's Avatar
slhf150
I just put on 31x10.50s and the clearance at the bumper when I turn is less than an inch.
Common wisdom on these boards is that 32x11.50 will fit the F150 4x4 without mods - but I think there would be some rubbing as mentioned above.
If you're willing to cut or space out the bumper and cut the front fenders and put on bolt on fender flares, you ought to be able to run your 33s. You may need to change to a wheel with a slightly different offset.
Old May 28, 2010 | 11:03 AM
Hitokori's Avatar
Hitokori
if u use 33x12.50 15s get 15x10's with 4" of backspacing
Old May 29, 2010 | 05:42 AM
TexasGuy001's Avatar
TexasGuy001
I would not run anything bigger than a 32 11.50 with no lift. If you do decide to lift, don't go with a body lift. Unless this truck is a farm truck or a beater, don't cut it.
Old May 29, 2010 | 05:43 AM
TexasGuy001
With no lift, I think that wheel/tire combo will end up rubbing the fenders.
Old May 29, 2010 | 10:04 AM
BCHauler's Avatar
BCHauler
They won't rub the fenders if you install f350 front coils. And space out the front bumper.
cwp_edwards
Sep 14, 2012 10:49 AM
fordjailbar
1947 and Older Ford Trucks
Apr 5, 2009 09:20 PM
AC94EXPLORER
Dec 20, 2008 06:19 PM
mikedeason
Apr 2, 2007 10:38 AM
ford311
Sep 21, 2002 08:51 PM
