Need help with simple electrical problem
Old May 27, 2010 | 08:21 PM
Robert6401's Avatar
Robert6401
So, in searching for the reason for my weak trailer brakes, I noticed that the plastic sheath on the ground wire coming from the truck side of the 7-pin plug has a small break in it and the copper is exposed a little. Is it possible this could be causing a short or something? And if so, how should I repair it? Thanks!
Old May 27, 2010 | 08:54 PM
DieselCamper01's Avatar
DieselCamper01
Would not cause a short but could cause a weak ground connection which will make your lights and such do some goofy stuff. I am not sure how that plug is constructed so that is about all the help I can offer. Good luck Bob
Old May 27, 2010 | 08:58 PM
Robert6401's Avatar
Robert6401
Thanks Jay. I just need to know how to fix this break in the sheath. Normally I'd just put electrical tape on it if it was in the house, but I don't think it would hold up back there at the plug location or if that would fix the weak ground problem.
Old May 27, 2010 | 09:08 PM
rbaker6336's Avatar
rbaker6336
you could use liquid tape,it holds up pretty good.It normally need a few coats
The trailer brakes may also need adjusting causing them to be weak
Old May 28, 2010 | 05:48 AM
Robert6401's Avatar
Robert6401
The trailer brakes have been adjusted. I need to get something done before we leave for a camping trip today. Anyone?
Old May 28, 2010 | 06:55 AM
just another truck's Avatar
just another truck
Clean you ball and reciever,
Run a jumper wire from your bumper to the trailer and try it.
Old May 28, 2010 | 07:20 AM
Robert6401's Avatar
Robert6401
It's a 5th wheel. And I hate to say it but I don't know what you mean by run a jumper wire.
Old May 28, 2010 | 07:42 AM
jdw1's Avatar
jdw1
Have you tested your brake controler? I just had one fail yesterday when I hooked up! Test it and make sure you are getting enough voltage to the trailer. You also want to see if the voltage is getting to the magnets.
Old May 28, 2010 | 09:23 AM
DieselCamper01
A jumper wire would just be running a different ground wire from the vehicle to the trailer. Not so easy to do on the 5th wheel
Old May 28, 2010 | 10:04 AM
just another truck
What Jay said, on both points.. sorry...
Old May 28, 2010 | 11:09 AM
60RatRod's Avatar
60RatRod
go to a .99 cent store and buy a 12V test light and package of alligator clips to make a jumper, it will make testing the circut a lot easier. then just keep following everyones advice thus far. You can take any length of wire you need attach alligator clips on both ends to make a quick jumper.
Old May 28, 2010 | 11:33 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
It's likely that you have high resistance in your ground wire. This will DEFINITELY cause you some grief. Even in Montana where we have a negative relative humidity most of the time, the wires begin to grow green fur and lose their ability to transfer electrons.
You, being in SC where walking in the clouds never ends, are sure to have some corrosion inside the insulation.
Don't tape it, scotch lock it, or even cover it up with sealant. The damage is done and you will have to solder and heat-shrink the connection.
nflfreak43
Tennessee Chapter
101
Feb 10, 2010 12:47 PM
BigF350
S. California Chapter
16
Jun 16, 2008 09:24 PM
Flip4ford
Kansas Chapter
15
Jul 5, 2007 12:25 PM
true4.2
3.8 & 4.2L V6
Nov 24, 2003 02:19 PM
odie780
May 1, 2002 03:01 PM
