No to mention, in my personal experience, I'm having problems fitting the lower rad hose. It already burst and left me broke downonce already.
If everything is done right it should be fine though. I don't think this kid's dad is going to let him actually go off roading in this truck. No offense implied, I just get the feeing the parents are over protective - and I'm not saying that's a bad thing.
Body lifts are the worst way to lift a truck. There is a reason they only cost about 100 bucks. They also increase the center of gravity without having stiffer springs to compensate for it. There is also fitment issues with the fan shroud, and shifter and possibly the steering column. Besides that they make the truck look out of whack because nothing lines up right afterwards. Its really a half *** way of lifting a truck. I think they should all be recalled and everyone given their money back.
All right. Did know if you didn't like it because of safety concerns or because you're one of the ones that thinks the tires should be stuffed up in the fenderwells
Thats cool. Yeah, I don't like tires stuffed in wheel wheels either. I like 31 10.50 max for 2wd and 32 11.50 max for 4wd.
i would agree if we were talking a huge body lift with a suspension lift but a 2 inch body can be a very helpful way of getting a size or two bigger tires under a truck. bigger tires means more clearance which can make a big difference when wheeling. a 2 or 3 inch body lift, bigger tires, and upgraded shocks are perfectly safe. and as far as things lining up right, Ive only known one person who had a body lift not line up right and that was because he had a ****ty suspension lift and WAY to big a body lift. i know at least 6 people with body lifts who use the trucks as daily drivers and wheel the crap out of them and have never had one problem with the body lift. a couple of them are the dumbest hicks and they put them on themselves.
I don't know about larger tires but I know when I went from 255/70/15's to 235/75/15's it was a very large difference in how it rode, about like the difference between having absolutely no shocks to putting some nice gas-charged shocks on, and mine aren't even light truck tires.
As for removing the body lift, I'd say go ahead and do it for the lower center of gravity since it's a flareside it's got a shorter wheelbase anyway. I suggest replacing the body bushings and such while you're down there though, otherwise it'll end up squeaky later on down the road.
Also jack up the truck and check those disk brakes, drum brakes and brake lines, if there's anything you even consider anywhere near questionable, replace it. Trust me, as a new driver nothing is quite as much of a brown seat moment as pressing the pedal to the floor and the vehicle not stopping.
